Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 173
Thread: Fixing to start slam
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    IM FIXING TO START MY SLAM..MY READINGS ARE BELOW...IF MY NUMBERS ARE CORRECT, I NEED TO GET TO 24 FOR SHOCK LEVEL..ADD 262OZ OF BLEACH TO START..
    here are my readings..plz conform I did it correctly with chlorine test
    TA=100
    PH=7.6
    CH=220
    FOR THE CHLORINE I USED THE 10ML MARK WITH 1 SCOOP OF POWDER...IT TURNED PINK LIKE IT WAS SUPPOSE TOO, AND IT TOOK 12 DROPS TO CHANGE IT TO CLEAR..DIVED THAT BY 2? FC=6 ?? THEN WHEN I ADDED A 5 DROP OF R0003, THE WATER STAYED CLEAR....SO "0" FOR CC?
    SORRY IT TOOK 13 DROPS FROM PINK TO CLEAR
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Starting slam
    TA=100
    PH=7.6
    CH=220
    CYA AT 60 AFTER PARTIAL DRAIN
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Starting slam
    Looks like you did the FC/CC testing correctly. 13 drops would be 6.5 ppm. Get that FC up and keep it there as much as you can.
    Also... ease up on the CAPS LOCK. It's hard on my ears.
    Isolated Spa - 345 Gallons
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Re: Starting slam
    lol....my bad...better??
    lovestoswim's Avatar
    May 2015
    Milford, Ohio
    102
    Re: Fixing to start slam
    That is correct.... Since it took 13 drops your FC is 6.5
    What is your CYA? That will determine what you will want to keep your FC at during SLAM.
    Happy Slamming!
    24,000 gallon, 21x43 Oval Wilbur AGP installed June 2015. 10'X24' deck. 2hp Aqua Pro Cartridge Filter. Using TFP method.
    Jun 2014
    15,255
    Don't forget to drop your pH to 7.2 before raising the FC.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    I already put 262oz of bleach in my pool about 2hrs ago...how long before I check to see what level its at? do I need to lower ph now if I already started?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by mepcards View Post
    Now is a good time to recheck FC. If it's below 10, test pH and TA again and add acid and then resume the SLAM. If FC is above 10, ignore the pH for now and keep SLAMming. You don't want to lose momentum.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    going to check now..also just bought 12 more jugs of bleach..total 16 jugs..lol
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    TA=100
    FC=20 ( TOOK 40 DROPS)
    When I put the 5 drops of r003, it kinda looked a very very light pink, so I added drop of 871 to turn clear...so 1.0 for cc? I need to go add bleach..didn't check ph since over 10
    Richard320's Avatar
    Jan 2010
    19,067
    TA=100
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    will I check again tonight? or in the morning
    Richard320's Avatar
    Jan 2010
    19,067
    The SLAM article says,
    Test and adjust chlorine levels as frequently as practical, but not more than once per hour, and not less than twice a day. Chlorine additions should be frequent, especially at the beginning.
    Right before bed is a good time, because all the bleach can work on algae-killing and none gets lost to UV rays from the sun.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    yes ill def be going to store buying more reagents tomorrow.....especially with so many drops 0871
    Richard320's Avatar
    Jan 2010
    19,067
    Use a 5 ml sample and each drop is 1 FC. Not precise enough for the overnight loss test, but good enough for dosing and saves reagents.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    whats also weird is when the pump was off for 4 days and low water level, the algae hardly showed up..once I filled up and pump turned back on, the normal areas starting popping up quickly..thought would be worse when pump off and no circulation..
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    didn't know I could do that...dang a lot of info in here..lol....mine doesn't have the 5ml mark so just split between the 10ml...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    It was growing, you just couldn't see it yet.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    but when use the 5ml mark will I divide or times the amount of drops..sorry
  20. Back To Top    #20
    Jun 2014
    15,255
    If you use the 5ml for FC testing, each drop is 1 ppm. No multiplying or dividing.
