Results 1 to 17 of 17
Thread: Just opened new AG pool today.
    Jan 2016
    Wichita, Kansas
    92
    Hello, thanks for adding me here! After several months of issues, we got our AG 16x28 running. It rained a lot while they were installing the liner and starting to fill. Now we have bright sunshine today.
    I am wondering what to test for right off the bat, I did check Chlorine (1) and PH, (above 8.2). Im using the TF-100.
    AG Doughboy 16x28', Opened June 2016
    Aquaview 20" filter w 7 position valve
    1-1/2 hp Powerline Pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Just opened new AG pool today.
    Test everything but CYA once it's full and circulating. Tap water won't have any in it, so it will be zero.
    If pH is at the top of the scale, it may well be off the scale. So if you add acid and don't see pH drop, it doesn't mean you did something wrong. Just repeat it until the color changes and then you'll know where you;re at.
    Jan 2016
    Wichita, Kansas
    92
    Thank you, yes, I just checked the CYA and that black dot didn't disappear. Haha. How much acid should I add to start? And just add acid?
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Tfaff View Post
    Can't say. Don't have full info.
    You're going to have to learn this sooner or later, so... here's how to use poolmath. Pool School - PoolMath
    Post your results and what you think needs to be added and we can check you before you start dumping things in. Oh... and Pool School - Recommended Pool Chemicals tells you how to add each chemical, too.
    Jan 2016
    Wichita, Kansas
    92
    Thank you, I read them a couple months ago but now I actually use the info and learn it!
    TF-100 Test Kit
    Jan 2016
    Wichita, Kansas
    92
    OK, So I finished the tests and Im not sure what the pool math page is telling me.
    FC - 1
    Ph - 8.2+
    TA - 1600
    CH - 2500
    CC - 2
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,967
    FC - 1
    Ph - 8.2+
    TA - 1600
    CH - 2500
    CC - 2
    I suspect an arithmetic error somewhere. How big was the sample you used for TA and CH tests and how many drops did it take? If those readings are correct, your water is so hard you could walk on it.
    And have you seen the videos? https://www.youtube.com/user/TF100TestKit/videos
    Jan 2016
    Wichita, Kansas
    92
    ok, I was terrible in chemistry. I looked at them again and I have no idea where those numbers came from, sorry!
    TA is 220
    CH is 175
    Better?
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,967
    TA is 220
    CH is 175
    Better?
    Much!
    Now how deep is the pool, so poolmath can calculate the volume? The water depth, not the sidewall height.
    Jan 2016
    Wichita, Kansas
    92
    Its 46"
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,967
    So at 46" deep, poolmath says 11300 gallons.
    Plugging your now numbers into poolmath and selecting vinyl/tfp/bleach for the suggested values...
    1 quart of 8.25% bleach right now to get to 3 (That's for zero CYA. The target will go up after you add CYA) Do that even if you don't have any other chemicals standing by. Just plain laundry bleach, not splashless or scented.
    Then 4 lbs of CYA granules in a sock or two. Put one in the skimmer and hang the other in front of the return or off a pool noodle or something else that floats.
    By the time that is done, 2 quarts of 31.45% Muriatic Acid. Pour that in front of the return stream so it spreads out fast.
    That's it for today. Leave the pump run to get that CYA dissolved.
    Tomorrow, recheck everything but CYA and target 6 for the FC. The CYA needs at least a day after its all dissolved to get a reading, so save the reagent. Hopefully your CC will be gone. A lot of water companies use Chloramines to prevent pipe corrosion and it takes a day or two to bleach out.
    Jan 2016
    Wichita, Kansas
    92
    Thank you, I will do that.
    TF-100 Test Kit
    Jan 2016
    Wichita, Kansas
    92
    Ok, so I've added the chlorine bleach, the cyanuric acid is still dissolving not the pool. (But the Cya is 45 tonight...) I haven't added any mecuric acid but here are my test results tonight.
    fc - 5
    ph - 7.3
    ta - 100
    ch - 200
    cya - 45
    cc - .5
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,967
    fc - 5
    ph - 7.3
    ta - 100
    ch - 200
    cya - 45
    cc - .5
    If it's clear and warm enough, hop in!
    Jan 2016
    Wichita, Kansas
    92
    Should I keep the cyanuric acid in there to completely dissolve the 4#?
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    18,967
    Yep. If you don't want anyone playing with it while you're swimming, pull it and set it in a bucket then put in back later.
    Jan 2016
    Wichita, Kansas
    92
    Thank you. That was fairly painless!
    TF-100 Test Kit
