Results 1 to 11 of 11
Thread: New filter possibly?
    Jun 2016
    Belford. NJ
    31
    Hi. I moved into a house with a pool two years ago and have been struggling to keep it well-behaved ever since, since I've never worked with pools before.
    I have an FNS Plus 60 sq. ft. DE filter which I cleaned today after seeing the pressure go up 10 psi or more over the indicated starting point. I noticed some of the grids have been worn out pretty badly and cleaning the grids thoroughly is practically impossible since the bolts at the top thing are rusted in place. I did the best I could, dumped the 7.5 pounds of DE in the pool skimmer and waited a few hours, and the pressure is still high.
    I feel like I need a new filter, but a new DE filter is too much for us to afford right now, and I need some professional advice on what I should do. Thanks!
    Edit: I added some PhosFree and forgot to read the label which clearly states that it raises pressure. Oh well. Main concern still stands!
    ~12,000 gallons, in-ground concrete pool. 60 sq. ft. DE filter (FNS Plus). 2 HP pump. Outdoor.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New filter possibly?
    Welcome to TFP
    Just replace the grids and you will be good to go
    Pleatco PFS3060 Filter Grid for Pentair, American, Hayward, Pac-Fab (7 full + 1 half), 60 sq ft
    Stick around and check out some of the threads
    Jun 2016
    Belford. NJ
    31
    Thanks for the welcoming! I can't replace grids. Bolts are rusted in at the top so I can't remove the grids :/
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    What does the water look like -- is it cloudy or green? Can you see a quarter on the floor if you toss one in?
    What did the pressure say immediately before adding DE and immediately after adding DE? Was it normal or was it high from the get-go?
    Jun 2016
    Belford. NJ
    31
    High both. I can see the bottom but it's pretty cloudy - I shocked the pool today. It's green at the moment.
    Richard320's Avatar
    Jan 2010
    19,074
    If the pool is green, that explains pressure rising and flow decreasing within hours of backwashing.
    If the gauge doesn't move much, maybe it's bad? Does it go to zero when the pump is off?
    And finally, the maker of Phosfree even states that it shouldn't be added to pools with algae. They know it will clog everything up but good.
    Jun 2016
    Belford. NJ
    31
    Ugh I knew there was a finer detail I must've missed. Also, the gauge is perfectly functional, it does go to zero if the pump is turned off.
    What do I do now, since Phosfree is in the pool? What exactly does it clog, the filter grids? Would I have to open the filter itself and give the grids a wash again?
    Jun 2016
    Belford. NJ
    31
    Quote Originally Posted by cowboycasey View Post
    Where can I get a frame for those? (I don't know if that's the proper term) I can't remove the grids themselves (rusty bolts).
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by Quantum Pearl View Post
    Probably more than once. Try a simple backwash and recharge using 80% of the recommended DE to allow for what is stuck inside.
    Jul 2013
    Fletcher, OK
    3,353
    Sorry, thought it was just the grids, here ya go
    Pentair Grid Assy., 60 Sq. Ft. Filter - 59023300 - INYOPools.com
    You will get a discount if you join TFP
    Jun 2016
    Belford. NJ
    31
    Thanks a bunch! This is exactly what I was looking for!
