Thread: Excessive FC loss? Or something sinister.
    Jul 2012
    Forest, VA
    79
    This morning (715am)
    FC 15.5
    CC 0.5
    Cya 40
    pH 7.5
    Alk 110
    This afternoon (4pm)
    FC 8
    CC 0.5
    Cya pH alk same.
    My pool gets sun almost the whole day.
    Is this normal FC loss for a day with my cya or could something nasty be in the water? I am planning on an OCLT soon (prob Tuesday). I'm am almost out of R-0871 solution which is why I haven't started the process yet. Thanks for any replies.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Excessive FC loss? Or something sinister.
    Wellllllll, do you suspect something sinister since you had your chlorine at 15.5 with a CYA of 40? That is shock level not maintenance level. So with that.....I'd suspect something sinister.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2012
    Forest, VA
    79
    The last few days we have had heavy bather loads and seemed like my FC would drop more than it should. So I brought up to shock level and wanted to see how much I lose in a typical day. Just seems like a lot
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    How does the water look?
    Do the OCLT for sure. And if that good then you might want to increase the CYA.
    Jul 2012
    Forest, VA
    79
    Water looks good. Deep end just a touch hazy.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    OCLT in order but hazy water at high CL consumption= SLAM.
