Thread: Hayward Poolvergnuegen 2x vs. Polaris 360
    May 2012
    Lexington, SC
    132
    Pool cleaners overwhelm me a bit. Currently we have a Polaris 360 that we're having trouble with. It's been fine until last year. My husband's done everything to try and get it working to no avail.
    I'm researching different cleaners. When I got the 360, I did so because a friend has one and she loved it, plus it was on sale, about $100 less than it's going for now.
    At any rate, after some research, I'm weighing out the pros and cons of these two types of cleaners. We have a booster pump that we use for the 360. I wouldn't mind NOT using a booster, though, and just having something that can just run pretty much constantly, if that is an option with the Hayward. However, after reading more about suction cleaners, I'm seeing that the debris picked up goes through the skimmer line directly into the filter or basket near the filter. We have trees surrounding our pool and I'm wondering if a suction cleaner is actually a bad idea for situations like ours with the extra debris that we get.
    Thoughts/experiences?
    13,500 gallons
    Sand filter
    IG
    TF-100
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hayward Poolvergnuegen 2x vs. Polaris 360
    I bought the zodiac leaf catcher and installed between the wall and my Poolvergnuegen
    Amazon.com : Zodiac Cyclonic Automatic Pool Cleaner Leaf Catcher Canister : Patio, Lawn Garden
    you can see it here behind the hose
    May 2012
    Lexington, SC
    132
    Oh very cool. And you're happy with the Poolvergnuegen? Do you leave it running pretty much all the time? It seems like a lower cost method as far as electricity goes. But do you think it cleans as well as a pressure side cleaner?
    Jul 2013
    Fletcher, OK
    3,353
    I really like it and very happy, it does stay in my pool 24/7 when the pump runs it also runs... I am not sure if it cleans better or worse, it does not "scrub" the floor but it will suck up sand but nothing bigger than a golfball, it does leaves like crazzy, the trick is just running it, eventually it will hit the whole pool but there is no rhyme or reason it just turns and turns
