Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Iron Removal
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Iron Removal
    Filling pool from hose (municipal) and I've got a yellow green cloud. I had the iron level tested reading 0.6ppm. I'm considering running it through a filter to see if I can get some out. RS22-SS2-S06 this is the particular filter in thinking of trying. I already have the housing this brand fits. Thoughts? Not crazy about having to sequester.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Iron Removal
    Try layering some paper towels in the skimmer to catch the Iron.
    A Tale of Two Filters... and Ugly, Rusty Water.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    I saw that, do I need to addsomething to make the iron precipitate?
    Richard320's Avatar
    Jan 2010
    19,074
    Re: Iron Removal
    Quote Originally Posted by ckk81 View Post
    Not really. FC at target for your CYA and pH at the top of the scale (7.7, 7.8) should do it. If it's yellow, it's already precipitating; dissolved, it would be clear.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Is .6 ppm alot of iron?
    Richard320's Avatar
    Jan 2010
    19,074
    Re: Iron Removal
    Yes. I think the staining threshold is .3.
    Have you tried the paper towels?
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Not full enough to run through the skimmer. Currently running through filter I mentioned previously with a submersible pump.
    Richard320's Avatar
    Jan 2010
    19,074
    Re: Iron Removal
    There used to be a great thread with great pictures but the guy took down the pictures. He made a filter by stuffing an empty gallon jug with pillow stuffing and punched some holes in the bottom and used a small pump to fill the mouth. Cleared what looked like coffee in a day.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    I asked the home furnishings folks which pillow was best for iron, but all I got was blank stares 😉. Running my filter setup overnight will report in.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Filter on the right is post after running 12. Definitely a change. Going to keep running to see if the filter gets darker. Any more thoughts?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Iron Removal
    How many microns is that filter rated for? You'll have the most success with a 1 micron fiter if one is easy to get for your housing.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Quote Originally Posted by Swampwoman View Post
    5
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    My device and my laboratory.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Added a secondary (sockendary?) filter already picking up some color.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Something brown has definitely accumulated on the bottom overnight.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Iron Removal
    Ckk, vacuum that to waste if you can without kicking it back up.
    Also, if you swap that 5 micron filter for a 1 micron filter you will catch more iron
    Lastly, since you're in an experimental mode, I should mention that I am presently doing a test with Alum floc and iron. Alum foc (or any floc) is not normally recommended at TFP due to sulphates, unrelability, and the potential to mess up your filter.
    But, if you can vacuum to waste and have a unique situation, there are times it might turn out to be useful.
    In my experimrpent, I took a 5 gal pail of raw well water with 2 ppm iron. I added 1/2 teaspoon of Leslie's Alum. The orange has flocced to the bottom and it hasn't even been 24 hours yet.
    This ratio roughly represents what 12 lbs of Alum (this type only) would do in 10,000 gallons of pool water.
    Tuesday, when my refills on iron test come in, I'll be able to report how many ppm were removed this way. I can already see that the water above the floc mass is crystal clear, so I'm optimistic.
    Helpful Links:
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: Iron Removal
    Ckk, I just realized your in Kzoo and you're salt water.
    While I'm cautiously optimistic that your mechanical filtering will reduce your iron load, I'm not as optimistic that you'll be able to avoid something like Jacks Purple...just that you won't need as much. Pool Chemicals, Hot Tub Chemicals and Supplies | Pool Geek carries it and reaches Mi locations overnight. Fingers crossed that you can just skip it...but just in case
    Secondly, in your town, The Water Boy has a 12,000 gallon tanker for $499...decent price for size if you ever find you need to dilute. I have his number somewhere if you ever need it.
    Lastly, is that liner floor Seabrook, and who did you get it through? I'm getting ready for a liner change up in GR and can't seem to get that border from my preferred vendor, but can get Seabrook borderless.
    Helpful Links:
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Very interested in your findings. I thought about a 1 micron, but was afraid it would clog quickly. I'm switching filters periodically and cleaning them with Iron Out. What if I add floc and then run through my DE filter? Would that catch it?
  20. Back To Top    #20
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Iron Removal
    Liner pattern is Modesto from GLI. http://www.glipoolproducts.com/assets/modesto_pp.gif
