Results 1 to 8 of 8
Thread: Setting CYA levels on a new fill.
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    Where would you folks set your CYA level in a newly filled pool, and what product do you suggest I use? I am using BBB so i won't be getting any CYA from pucks. Thanks!
    "Beer is proof God loves us and wants us to be happy." -B. Franklin
    In-ground, vinyl lined, 20'x40', 3-10' deep, solar heater, sand filter, 3/4hp pump, Dolphin Pro, Cover Star Auto Cover.
    A proud BBB convert.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Setting CYA levels on a new fill.
    Because you have a sand filter, and will have routine water replacement because of it, I would target 50, and it will slowly drop over the summer. Keep it between 30-50 and target your FC accordingly.
    CYA is sold under various names, most commonly stabilizer, conditioner, or cyanuric acid. It is sold in the pool departments of many big box stores, and by pool stores.
    Thanks for the Question and answers... I had the same questions...I added 3lbs of 99% conditioner and still can't get a reading with my tests.
    -inBamaNow
    16x32 Hydra Liner, Hayward 24" Pro Sand Filter, WhisperFlo 1HP Pump, Hayward CL200, AquaChem Test Kit =[
    11,969
    Quote Originally Posted by inbamanow
    Does it say Cyanuric Acid on the active ingredients label?
    Jun 2007
    NC
    255
    ...I added 3lbs of 99% conditioner and still can't get a reading with my tests.[
    Remember that it takes 5-7 days for the CYA to completely dissolve. If you have to backwash during that time period you'll be washing out some of the undissolved CYA.
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    Yes, it does say Cyanuric Acid on the active ingredients label...
    and oh yeah, 5-7 days... why don't I know anything. =] Backwashed before i dosed with the 3lbs and water is crystally clear and ready for stabilization for sanitation and then I leave for vacation.
    -inBamaNow
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    The detection level of most kits is 30 ppm CYA, unless you have the 20 ppm kit. According to the Pool Calculator, if your pool's size is more than 12,000 gal, 3 Lbs of CYA will bring your CYA level under 30, which means you won't be able to detect it.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
