Results 1 to 15 of 15
Thread: New to pool ownership
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    Hi, moved into a house about a month ago and it has a pool. I am happy to have found this forum, I am taking to time read before asking a bunch of questions. I started looking for help because our salt water generator reads 0, when it used to read 1800. Pool water was tested yesterday at a local store and salt water amount was 2200. I am going to purchase the recommended TF100 test kit.
    We've never had a pool before so it's a lot to learn, luckily the previous owner is helping with getting things going. But I'm still having issues getting the right levels.
    Thanks for sharing all your knowledge
    -bbp
    35k gallons, in ground, plaster, Pentair Clean & Clear Plus, Bioguard, Mineral Springs salt water, Centurion for Pac-Fab 1hp
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New to pool ownership
    Welcome!
    Don't let that pool go green on you while you figure out the SWG! You can just add bleach by pouring it in front of the return. If you have any kind of test results, you can figure out how much. If not, let poolmath tell you how much bleach adds 3 ppm per day and add that per day.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    Thanks, I've shocked it a couple times. The water is mostly clear. I'm going to try and attach a picture of the printout from yesterday's water test.
    Richard320's Avatar
    Jan 2010
    18,967
    That pool store printout won't cut it for day-to-day. FC is constantly dropping dues to sunlight and anything organic that falls in the pool. You have a giant pool, so 1.3 jugs of plain 8.25% bleach or the equivalent of stronger pool stuff should put you in a holding pattern with FC.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    Thanks, I'll add that tonight.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    Forgot to ask, how often should I add the bleach and how long after can we go in the pool?
    Thanks
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Bbp View Post
    Thanks
    Daily. That's probably why they installed the SWG -- to save the hassle. Fifteen minutes after pouring the bleach in front of a return should be plenty of wait. Less if you brush immediately afterwards to mix things up.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    When you say return do you mean the filter?
    Richard320's Avatar
    Jan 2010
    18,967
    Wherever the water shoots back into the pool. Just pour it in front and it will get diluted and spread. Watch for it. You'll see a yellowish cloud just expand away into nothingness.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    Great thanks
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    Can you tell me if either of these pictures show the return? I don't feel air or water coming out of anywhere. I don't see any other holes. Thanks
    Richard320's Avatar
    Jan 2010
    18,967
    I see three returns. Two in the top picture and one just below the skimmer in the second.
    If the pump is pumping, water has to be going back into the pool somewhere.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    I just asked the previous owner. There are cleaning jets on the bottom of the pool and that's where it returns.
    Richard320's Avatar
    Jan 2010
    18,967
    There should be some kind of valve to direct water to the eyeball returns, or they wouldn't have bothered installing them.
    But nevermind that -- you need to get some chlorine in that pool before it turns green. If you can't figure out the valves, just pour the bleach in and then use a brush to mix it up good. Pump on, so it spreads fast.
    Bbp's Avatar
    Jun 2016
    Westminster, md
    38
    I put in a bottle and a third in front of the pop ups that were up.
