Thread: Solar controller. Are or fair and Hayward valve actuators the same?
    Sep 2015
    Las vegas nv
    96
    I'm hooking up my Pentair LX-220 solar controller and it turns out the transformer is bad. Found them online for about $70 or I can get a whole new Hayward gl-235 controller from Amazon for $187. The Pentair unit has been sitting around for a number of years so not sure how long the rest of the components will last. From the pictures it seems the actuators look very similar and have similar electrical connectors. Does anybody know if they are interchangeable?
    10k Gal, IG Gunite, 10' X 28' X 5.5', Quartz, Hayward Ecostar VS 2HP, Hayward 325 sq ft, 2" plumbing, 2 24" sheer decent, 2 bubblers in tanning ledge, Hayward LED, Build Date Dec. 2015. auto pool cleaner suction side. Suntrek Solar panels, Taylor K-2006
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Solar controller. Are or fair and Hayward valve actuators the same?
    Yes, all valve actuators are interchangeable.
    Mark
    May 2015
    Land O Lakes, FL
    527
    I bought the intermatic actuators from Amazon. Working great with my pentair system at a fraction of the cost of the "name brands".
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Sep 2015
    Las vegas nv
    96
    Good to hear. I'll probably go with a whole new controller to be on the safe side.
