Results 1 to 12 of 12
Thread: Trouble with getting pool open
    Jun 2016
    New Orleans
    17
    Having lots of trouble getting water cleared up for season.
    Went to pool store and put in lots of chemicals which essentially didn't help.
    Ordered TF 100 test kit and found very high CH, CYA and FC.
    Drained about 1/3 of pool and replenished.
    Water is blue with dead algae on bottom which we vacuumed. Cloudy water, can't see drain
    Tried Ultrabrite last week twice which did not help.
    Numbers have improved today.
    PH 7.2
    FC 18
    CC 0
    TA 80
    CH 450
    CYA 90
    Any suggestions appreciated!
    36,000 gallon, in ground, gunite, Triton II sand filter, Whisper flow 1HP pump, polaris sweep
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Re: Trouble with getting pool open
    Wow. Great job on getting a good test kit and knowing to drain do to high CYA. Welcome to TFP
    to clear the water you'll need to follow the SLAM process
    Shock
    Level
    And
    Maintain
    So according to your test results your current chlorine is not adequate to be killing algae faster than its multiplying in your pool. With 90 CYA, you'd need to be at 35 FC. I would suggest draining some more to get that CYA lower if you can. It CAN be done with 90 CYA but that's a lot of bleach and a lot of test drops.
    Pool School - SLAM - Shock Level And Maintain
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2014
    15,268
    I agree. Unless you want to maintain such a high SLAM and daily target FC level, consider another partial water exchange. It will help in the long run. It's fantastic you have the TF-100 to understand and be in control.
    Jun 2016
    New Orleans
    17
    Thanks-I think draining more water is the best way to go in the long run. Any ideas on how much more to drain?
    Another 1/3?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    1/3 or a little over should put you in the right ballpark, just don't over do it, if you have been getting rain at all like we are on my side of the state and the ground is saturated you don't want to take a chance on the pool floating up out of the ground. Like this random picture from google
    Jun 2016
    New Orleans
    17
    Drained out another approx 8000 gallons
    Current numbers after replenishing water and a couple hours of running filter
    PH 7.5
    FC 6.0
    CC 0.25
    TC 6.25
    TA 80
    CH 400
    CYA 55
    Water is still cloudy and getting greenish
    Add bleach?? How much??
    Jun 2016
    New Orleans
    17
    Also, this may sound dumb, but I find the pool calculator confusing-the boxes-"goal" and "Not set up"
    Which numbers go where?
    Am I supposed to come up with my own goal numbers?
    Can someone explain how to use it properly?
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    I find the Pool Calc iPhone app easier to use.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Jun 2014
    15,268
    On the calculator, make sure to enter you pool gallons at the top. From there, each row you enter your NOW number as currently tested, then your desired number in the TARGET field. On the FC row, make sure to manually enter the bleach percentage (weight). Near the bottom, update the 3 criteria (Troublefreepool.com, your pool type, and how you sanitize (bleach, SWG, etc). The calculator will help you with the rest.
    Jun 2016
    New Orleans
    17
    Thanks-I guess part of my confusion is coming from the pool calculator I am getting under "pool math" (above) doesn't say "now" and "target".
    It says "goal" and "not set up."
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    On this? http://www.troublefreepool.com/calc.html
    Top left next to the calculate button is Now and Target
    Here is a tutorial on how to get it all set up.
    Pool School - PoolMath
    Jun 2016
    New Orleans
    17
    Thanks so much! I think I understand that now!
