Thread: Question re attaching new pump to existing piping
    May 2016
    topeka
    7
    hello tfp friends. well, i have a handyman who looked at my new pool pump from inyo (all in one motor, pump, filter) and he feels he can hook it up.. I could use a second or third opinion about something.. the length between the filter end of the new pump and the opening where the pipes come from the pool, where they will attach, is very short and has been cut and re connected a time or two.. This handyman says it is too short, or maybe too cut up for him to connect the pump to the pool pipe in a straight line of piping and he says he will need to do a curve of some kind.. I am concerned a curve instead of a straight line of piping right into the filter will affect the performance? I have a photo attached.. I'm not exactly sure why he can't do a straight line,, what do you all think? thanks in advance. )** i just tried to upload a photo,, i think i did it correctly, not sure though
    big blue skies kansas
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Question re attaching new pump to existing piping
    That three way valve is dual-diameter. One size pipe fits inside, as it is now, and the next size up fits the outside. So saw if off flush and install a coupler on the three way and then either reduce it back to that size or leave it large all the way into the pump.
    May 2016
    topeka
    7
    ok, thanks, I'll tell the handyman this., or maybe find a real plumber.
    mas985's Avatar
    Pleasanton, CA
    11,741
    If the handyman did not know this, he shouldn't be doing the work.
    Mark
    May 2016
    topeka
    7
    that's what i was kind of thinking.. i've just been searching out plumbers.. thanks.
