Thread: Panel says (Hayward) chlorinater is "off"
    Dec 2015
    Wilmington, NC
    10
    I've scrolled through every menu and I'll be darned if I can figure out how to turn it "on"! Fwiw, it took an algae bloom for me to realize it was even off. I turned the super chlorinater on per my builders instructions while shocking it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Panel says (Hayward) chlorinater is "off"
    There are several Hayward chlorinators. Which do you have?
    A signature with your equipment is helpful when asking a question.
    Pool School - Read This BEFORE You Post
    Mark
    May 2013
    Michigan
    9
    What Hayward do you have? There are many... Mine is a SwimPure with a t15 generator. Algae blooms??? Grief! Seems like you have water problems/chemistry. SWG systems require balance to the water before they function correctly. I know, didn't help you.
