Thread: Newbie pool owner needs help.
    Jun 2016
    west Islip NY
    1
    I just open my pool for the first time after I had it winterized by a professional. I can't get the pump going. I tried to prime it. Water gets sucked down and disappears. Maybe I don't have my connections attached right (picture attached) Also the collar is leaking (picture attached) I think it's stripped just spins doesn't tighten, do I need teflon tape on it? how do I replace that maybe that is causing the pool not to be pressurized? Any help is appreciated thanks.
    16 x 32 Inground pool 20,000 gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Newbie pool owner needs help.
    If that collar isn't absolutely airtight, the filter will suck air instead of water. If it spins endlessy, something is stripped and will need replacing.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    More than likely have a valve handle pointing in the wrong direction---but I'm no help there!
