Thread: Leaf Vac
    Apr 2016
    Ada
    7
    Question Leaf Vac
    My pool has a built-in debris collection system that sucks debris from the deep end and collects it in a mesh bag. The bag is in a unit that looks similar to a skimmer - I.E it has plastic round cover that is built into the pool deck. Under that is a round glass cover (about 8.5 inches in diameter)that seals the system.
    That cover is cracked. The problem is, I don't know the industry name for the system to find a replacement part. I am hoping someone here might have an idea.
    Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Re: Duplicate - Ignore
    Apr 2016
    Ada
    7
    Leaf Vac
    It's similar, but not the same. Thanks for replying. Just knowing a general name for it is helpful.
    Feb 2015
    Chandler AZ
    933
    Re: Leaf Vac
    Here's a different brand......
    Debris Containment Canister - Paramount Pool and Spas
    https://www.google.com/search?q=para...obile&ie=UTF-8
    Does your pool have an in floor cleaning system (pop ups)? If so, look for a manufacturer for it. Your in deck leaf catcher is probably from the same maufacturer.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Leaf Vac
    Could you post a picture of the thing... 😊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
