Thread: Pool Math
    Feb 2016
    McKinney. TX
    42
    Pool Math
    I think I asked this before, but cannot find it. Does the Pool Match calculator take into account the CYA numbers in providing TA goal numbers? As I understand it, "adjusted" TA is roughly .3 to .33 less than the measured TA due to the impact of CYA and pH. Does the calculator just input and output measured TA numbers while internally calculating the impact of CYA?
    12,000 gallon, in-ground, Lunar Quartz-Bermuda finish. Pentair Intelliflo Pump and Pentair cartridge filer. Polaris 280 pool sweep. Circupool SJ40 SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Pool Math
    It uses the raw numbers from a Taylor-type drop test kit and adjusts internally.
    See for yourself. Plug in your numbers and look at CSI. Then alter the CYA and see what it says. It does take CYA into account.
