Thread: Saltwater system still need a pump?
    Hey everyone. I am a TOTAL newbie to owning a pool or knowing anything about them.
    We decided to start looking into pools and as ive googled around, ive figured out that apparently sand filter pumps are the best for total chlorine pools, but a lot of people love saltwater pools even better. They sound like lower maintenance and less expensive. We chose an Intex pool 18' wide and 52" deep with a sand filter but now ive decided I want a saltwater system. Do I still need a pump/filter or does the saltwater system do all that? thanks!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Saltwater system still need a pump?
    A salt water chlorine generator is a separate piece of equipment from a pump and a filter which are also separate. A salt pool IS a chlorine pool btw and a sand filter could care less! Welcome.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello, Pool School - Pool School is your friend.
    The basics: Chlorine (liquid (in the form of bleach) or gas (formed in a SWCG)) kills the nasties. The filter catches the dead nasties. The pump moves the water with the dead nasties to the filter, the filter catches the dead nasties, clean water is returned to the pool, and repeat.
    How you add chlorine is pour it in, or generate it in a SWCG (Salt Water Chlorine Generator).
    ALWAYS maintain a proper Chlorine/CYA level. It's best to run your chlorine level a little high then low.
    Knowledge is power, too little knowledge is dangerous...
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    You just install the SWG after the pump and return the water to the pool simple and effective
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
