Thread: cya chart
    cya chart
    it's been a while since i've been on, but way back, i setup my pool according to the big cya chart and always ran bout 35-40ppm cya and followed the recc FC levels. i just ran across the simplified version in the school, and it seems to show not less than 70ppm for SWG pools... i looked through the older 5 page thread about the chart, but didn't see any reasoning for this. why should the cya be double for swg pools?
    school chart
    IG, PebbleTech, 26 x 15 kindey+spa, 16000 approx. gals, 2.25hp 2 spd hayward pump, 2 1/2 plumbing, cartridge filter, SWG, navigator, Long Beach, CA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: cya chart
    This is one of the more frequently asked questions here. Rather than wear my fingers out typing a response that may be incomplete, check out these threads.
    Re: cya chart
    thanks, sometimes it hard to find the right keywords to filter through everything. that helps.
