Thread: Vacuuming out the last few inches of water & GUNK...
    Jun 2016
    Walterboro
    4
    I have a 24' above ground pool. We drained it this winter due to some problems we were having. I drained it with a gravity syphon and it got all but about 6" from the bottom.
    My plan was to just hook up the vacuum hose to my pool pump & just waste out the remainder before cleaning & refilling this spring. Well, spring turned to summer faster than I wanted & here I am with 6" of gunk remaining in my pool.
    My problem is that I can't get the vacuum to catch prime. I've filled the pump with water, filled the hoses with water, but I still can't get it to catch.
    Suggestions???
    Thanks in advance for your help...
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Vacuuming out the last few inches of water & GUNK...
    Is this an Intex pool? If it's a permanent steel wall above ground, you shouldn't drain the water fully unless you plan on replacing the liner. The liner loses its elasticity after filling and if you drain it, it can shrink.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Sounds like it's time for the bucket brigade. Or a wet-n-dry shop vac, five gallons at a time.
    Jul 2014
    Oakbank, Canada
    389
    I use a utility pump, sucks it down to about 1/4", then use a plastic scoop I made out a out of a washer fluid bottle for the rest. I scoop the water up and into a 5 gallon pail. Then I use some old towels to finish up, wring them out over the side.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
