Results 1 to 8 of 8
Thread: New to forum
    wmak's Avatar
    Jun 2016
    Carrollton, KY
    4
    New to forum
    Hey, all. I have had a vinyl pool for many years, but last season it went bad mid season. I have read some of the advice here, and am dealing with clouding and algae. I checked the CYA, and it's around 90, but the FC and PH are correct, as is the Alkalinity. Any advice would be helpful, I'm pretty discouraged at the moment.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,413
    Re: New to forum
    Hi, can you tell us the test results for FC, pH and CH are? Knowing the exact values helps us to troubleshoot the problem. Just saying they are correct doesn't give us enough information to work with.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    Re: New to forum
    You're gonna need one of our recommended test kits in Pool School to win the battle most effectively and cost efficiently. TF100.
    If your FC was "correct" for your CYA and maintained that way---you wouldn't have algae.
    wmak's Avatar
    Jun 2016
    Carrollton, KY
    4
    Re: New to forum
    So, I went out and re tested, and I got a pale reading on the PH, lower than 7.6, maybe 7.5? The fFC was off the chart, I had added granulated a few hours before. the CH never turned blue, but it cleared up at 4, 200 according to the kit. TA was 210 and CYA 90 I include pic of the pool under the test kit. Sorry about the sideways image, I can't find the edit setting.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: New to forum
    Welcome to TFP!
    Chlorine level is set based on CYA level and the Chlorine CYA Chart. To keep the pool sanitary and algae free the FC must remain above minimum at all times. The problem is that as you add dichlor and trichlor to the pool to chlorinate it also adds CYA which then requires higher and higher levels of chlorine. It is a Pool Store circle.
    Do a little reading here, Pool School - ABCs of Pool Water Chemistry
    And then here, Pool School - Getting Started
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: New to forum
    Hi and welcome to TFP
    To clear your water you'll need to SLAM your pool. Link below. But if you don't already have a FAS-DPD test for chlorine, you're going to need that.
    Pool School - SLAM - Shock Level And Maintain
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    wmak's Avatar
    Jun 2016
    Carrollton, KY
    4
    Re: New to forum
    I have created a signature, but I'm not sure how to make it appear.
    Oh, there it is.
    IG Vinyl pool 30K Tagelus sand filter Pentair IntelliFlo VS-3050 variable speed pump
    city water, no restrictions. Fas-Dpd kit ordered.
    DFW, TX
    24,509
    Re: New to forum
    Nice work so far!
