Thread: Cleaning DE filter cartridge
    May 2016
    Massachusetts
    14
    With the help of this forum my pool water is looking (and testing) GREAT.
    I am tackling my filter today. Replacing a corroding gauge with TFT version, new o-ring, and want to clean cartridge better now that I have filtered a swamp through it...
    What chemicals/cleaners, if any, should I use?
    Have had a hard time finding any help by searching.
    TIA!
    Tim
    - 30,000 gallon (16'x40' - 10' at deep end) gunite
    - Sta-Rite DE 60 sq/ft filter
    - AquaCal Heatpump (broken...)
    - new to pools and 110% clueless!
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Re: Cleaning DE filter cartridge
    1. Strong strady blast of water, followed by
    2. Mixing up a TSP solution; or powered dishwasher detergetnt (w/ dawn), both of which will break up grease/oils
    3. As a final step, a 1:4 solution of muriatic acid to water if you have any calcium buildup left on the grids.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    DE Filter Cleaning Tutorial should answer those questions.
    If the filters look greasy, TSP will get rid of it. If they feel crunchy, they might be calcified and need an acid bath.
    I've never used anything more than a jest stream of water.
