Thread: New to forum
    wmak's Avatar
    Jun 2016
    Carrollton, KY
    4
    New to forum
    I just registered, found this forum while looking to get rid of algae. I checked the CYA, and it's 90. How much water do I have to let out to reduce this? The algae came back after I put on the solar cover, the FC and PH are in the correct range, the Alkalinity is around 18 ppm. Thanks in advance fro any help.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New to forum
    Welcome to TFP!
    Quote Originally Posted by wmak
    ...the FC and PH are in the correct range, the Alkalinity is around 18 ppm.
    What are you using to test the pool water with? A few things seem odd about your test results. An Alkalinity of 18 seems way off and nigh impossible. Also, stating that FC and pH "are in the correct range" is a bit vague. If the "correct range" is based on traditional pool store criteria, these parameters may, in fact, not be in the correct range for your pool. As for the CYA level, I'm a bit suspect of the 90 ppm reading until I know what you are using to test with. I would hate to have you unnecessarily drain a significant amount of your pool water until it is confirmed that it is absolutely necessary. Please let us know what you are testing with and we can go from there.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: New to forum
    Welcome. Please fill out the signature line in your profile and list your pool type/size and equipment to keep from having to repeat it and get better help.
