Thread: Another Conversion Begins ...
    tikifarmer's Avatar
    Oct 2007
    South Central PA
    30
    I am planning on starting the much anticipated conversion to chlorine this weekend . Would it be good to vacuum the pool (still has the cover on right now ) prior to adding the first round of bleach ?
    23,000 gallon vinyl in ground / Hayward Superpump / Hayward sand filter / Liquidator / Borates
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Another Conversion Begins ...
    If there is a lot of crud on the bottom, sure why not.
    Good luck with the conversion, be sure to take before, during and after pics. We love pics.
    tikifarmer's Avatar
    Oct 2007
    South Central PA
    30
    Re: Another Conversion Begins ... (now w/pics)
    On Friday night I vacuumed as many of the leaves and such as I could get and on Saturday morning at 9am I began the long awaited conversion from Baquacil to Chlorine . All testing was done with TF100 test kit .
    As you will see in the pics I didn't see all the great color action nor any white stuff floating on top (no disappointment there), I am guessing due to the fact we have not put any Baquacil stuff into the pool since September of last year ...
    Pic before adding any chlorine . At this point I added 728 oz of 6% Chlorine
    11am tested .5 FC , added another 728 oz
    1pm tested 1.5 FC , added 637 oz
    3pm tested 3.5 FC , added 546 oz
    5pm tested 8.5 FC , added 273 oz
    7pm tested 13 FC / 6 CC / 7.5 PH , added 91oz
    10pm tested 14.5 FC , did not adjust
    The next day I could see the bottom easily in the shallow end and the main drain was just barely visible 9' down
    9am tested 6 FC / 5.5 CC , added 410 oz
    11am tested 10 FC , added 230 oz
    1pm tested 10 FC , added 230 oz
    3pm tested 9.5 FC , added 230 oz
    5pm tested 8 FC / 2.5 CC , added 320 oz
    9:30pm tested 14 FC / 1.5 CC added 45 oz
    11:30 tested 15 FC / 3.5 CC
    The next morning (after 48 hrs) things are looking pretty good , clearer yet ...
    Tested 10.5 FC / 2.5 CC added 230 oz
    11am tested 5.5 FC added 454 oz
    1pm tested 7.5 FC / 2 CC added 364 oz
    3pm tested 10 FC / 1 CC / PH 7.2 / TA 120 / CH 210 , added 230 oz
    7pm tested 6 FC / 1 CC added 410 oz
    9pm tested 16.5 FC / 1.5 CC
    This morning the pool is very clear ...
    6:30am tested 14 FC / 2 CC did not add anything , will check again at lunch and adjust as necessary , hopefully the CCs will come down in the next 24 hrs and at that point I will change the sand and add the CYA ....
    Thanks to all on here for a great website ...
    11,969
    Fabulous!
    Jul 2007
    Northern NJ
    299
    and fast!
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
