Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Question on preparing for slam
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    Im in the process of filling pool back up from partial drain. Once filled back up, and if im lucky enough that my cya is in levels for a slam, im curious to how much bleach ill need on hand...I know ill be needing a lot, but start with 5,10, etc jugs??? For ill be running to the store here in a bit..
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,649
    Re: Question on preparing for slam
    Gonna depend on how bad it is as to how long it takes. Depending on your CYA level, it COULD take 4 or 5 gallons just to initally reach SLAM level. Get a dozen to start.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    I have about one more hour and pool will be full, and then I can turn the pump back on..wish me luck on lower cya level..
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    actually filled up a lot quicker than I thought..pool is full and pump is on....how long before checking new cya levels? 30-45 minutes?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Quote Originally Posted by mepcards View Post
    Yeah. And brush some to get some cross currents. Picture adding creamer to a really huge cup of coffee.
    Apr 2010
    East Texas
    9,649
    Awwww...............let's make him wait 3 hours!......(just kiddin')
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    geeez..thanks woodyp...don't you think ive been thru enough already..lol
    Apr 2010
    East Texas
    9,649
    Yes I do, and you might as well laugh to help ease it.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    if my cya level is still not where it needs to be, and I have to drain more, my laughter will turn into full blown cussing....wait, ive been cussing already thru this ordeal..lmao
    Apr 2010
    East Texas
    9,649
    Just keep it off the forum!
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    cya testing is complete...I mixed half pool water and half tap....I was able to fill the tube all the way to top with out spilling over, and I could still faintly see the black dot...now I know I need to times that by 2, so assume im close to fifty? since 30 is the lowest on my kit? I did it back n forth a few times, and also had the wife look..she could make out dot too when the tube was completely filled
    Richard320's Avatar
    Jan 2010
    19,052
    Congratulations! You no longer need to use the dilution method to test CYA! That's a BIG improvement.
    You can run the test with 1:1 pool water and R-0013 to get the CYA figure. If you have any CYA reagent left, that is...
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    I have a little from my crappy kit, and a little left on second bottle from taylor kit..can I use both together just to get the reading?
    Richard320's Avatar
    Jan 2010
    19,052
    If they have the same number, yes. If the other kit is some other brand, I don't know if they're the same stuff. Do they have the same directions for the CYA test?
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    its the hth 5 way kit..same directions...I used both and just had enough....I did it over and over and tried to use the average...I have to say its 60 for my cya..one time I swore it was between 50 and 60 mark, then another time higher than 60...I did like 5 times and for the most it was around 60....drain more again??
    Richard320's Avatar
    Jan 2010
    19,052
    No. The season's about over already! Get SLAMMING. The initial dose will be a little higher than it would be at a lower CYA, but I'll bet the replenishment stays about the same.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    I need to test both ph and chlorine first....do I need to worry about ta and ch at the moment?
    Richard320's Avatar
    Jan 2010
    19,052
    Only worry about TA if it's below 50 and pH is off the bottom of the scale. Otherwise, no. And with a vinyl liner, low Calcium will never be a problem.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    ok cool..ill just test everything and post my readings....also im going to use the 10ml this time and only 1 scoop of powder
  20. Back To Top    #20
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    254
    here are my readings..plz conform I did it correctly with chlorine test
    TA=100
    PH=7.6
    CH=220
    FOR THE CHLORINE I USED THE 10ML MARK WITH 1 SCOOP OF POWDER...IT TURNED PINK LIKE IT WAS SUPPOSE TOO, AND IT TOOK 12 DROPS TO CHANGE IT TO CLEAR..DIVED THAT BY 2? FC=6 ?? THEN WHEN I ADDED A 5 DROP OF R0003, THE WATER STAYED CLEAR....SO "0" FOR CC?
    SORRY IT TOOK 13 DROPS FROM PINK TO CLEAR
