Results 1 to 7 of 7
Thread: New pump arriving today
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    343
    Hey all,
    My new krystal clear 2100 gps pump and filter will be arriving today. Any tips for making for sure all is done correct. Any inside tips for the sand I should use? Anything useful?
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: New pump arriving today
    Pool sand (silica sand). You can get at any pool supply or hardware store.
    It's a good idea to lube all the gaskets with a gasket lube (like Magic Lube). Also available at pool supply or hardware store.
    Beyond that, just follow the directions carefully and enjoy!
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    #20 silica sand is the stuff. 2100 gps gallons per second?
    Congrats! Lots of folks here who upgraded to that and are happy with it.
    chayne's Avatar
    May 2016
    343
    This new pump and filter is amazing. i got everything hooked up. went to Leslie's and got my sand. Home Depot or Lowe's did not have it. I cannot believe how much better this thing is over the other pump and cartridge filter. i can see a long and happy summer. My next plan is to change out the return to the positional eye ball and hard plumb. The pool has so much less "stuff" on the bottom than it did before. Within one hour i can tell the difference. Now all i have to do is get my PH level right and i will be good to go.
    Charles
    Coleman 16'x48"
    jmcdtucson's Avatar
    Jun 2014
    317
    Welcome to the future >:}
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    chayne's Avatar
    May 2016
    343
    It truly is awesome. Thanks for all the folks here on TFP that gave me the inspiration to do this.
    Charles
    Coleman 16'x48"
    DFW, TX
    24,509
    Nice work! It is always good when a plan comes together!
