Waterway 16 carefree issue
Jun 4, 2016
7
Akron ohio
New sand in filter. Ran start up several times. All settings working great except when I switch to filter. Water comes out strong for about 15 or less mins. Then very little water coming out to pool. Any idea way the flow drops in filter mode. Holds 100lbs sand and that's what in. Please any help would be great.
Welcome to TFP :)
You filter is doing its job and filtering something in your water, how does your water look :)
Did you put in more sand then the filter is rated to Handel?
Is your pump leaking anywhere from increased back pressure?
Has the motor been removed from the pump at all?
No leaks that I can find. Took all apart and back together looking for clog. Nothing found. Started doing it from the start. It's states 100lbs and that is what I put in. I'm lost.
16 inch holder for sand
