Thread: Calcium addition and other effects
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    As my last step in balancing my pool this season, I need to add 25 lbs of Calcium. How will this effect other chemistry? Is it going to do anything to the pH? Or anything I need to be aware of?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2014
    15,059
    Re: Calcium addition and other effects
    It should not change anything else, although it may give a cloudy appearance at first until the calcium increaser product you add has a chance to dissipate and mix thoroughly No need to worry if it does. It will go away on its own.
    Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. They are available in some areas as Peladow, Dowflake, Tetra Flake, or Tetra 94, often sold as a deicer by hardware stores, and some big box stores, in colder climates. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool.
