Thread: Building in 2017 - learning BEFORE I build
    Jun 2016
    Vancouver/WA
    3
    Hello,
    Great website. Several in the know pool owners recommended I check this out before building. I'm sold on the TFP maintenance method, so that's a leg up I think. But right now I'm on the build/plan stage.
    We are closing on a great house on nearly 2 acres, and it is a perfect set up for a great pool. The yard is flat and mostly sunny with no trees near the house. It's a blank slate with great landscaping on the perimeter but no major landscaping to remove near the
    We want to build an in ground pool with a large hardscaped area and a pool house. Very large flagstones or stamped concrete was the idea. A more contemporary look with a clean, rectangular pool.
    Right now I'm exploring cost and size, with some attention to placement. I'll consult with pool builders this winter to get some local expert opinions.
    So right now I'm just trying to get a ballpark estimate on cost, and what size pool is best.
    We want a pool to play around in. No laps, no volleyball games. No fountains, no slides, no waterfalls. Just kids and adults splashing around, etc. I do think we'll do some real nice lighting. again, a real clean, contemporary, almost modern look.
    For size, I was thinking around 20x30 and up to 5 feet deep. Could be persuaded to go deeper if diving is a big deal. If that size is too big or too small, I want to know now!
    For cost, the rule of thumb seems to be if the pool costs X, the hardscape, lighting, fencing, etc, will cost another X. So... what is a ballpark X for the size indicated above?
    I know there are variables... fire away!
    thanks in advance
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,245
    Re: Building in 2017 - learning BEFORE I build
    Who's building it and how much?
    This is a great thread and Welcome to TFP. You already made the three most important commitments... build a pool, join TFP and give yourself a year to get it done well.
    All the best and great to have you here
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi,
    Welcome TFP! You certianly came to the right place.
    You have a lot to consider in building the pool other than just the price and depth and things like that.
    The options of how to maintain the pool are many. Pumps, method of sanitation, automation and the like can drive a person to the brink of madness and can add a lot of dollars to the bottom line. We can certainly help with suggestions when the time comes.
    As far a how much it costs. A good rule of thumb, is to compare pricing per linear foot. Considering there aren't any special ground considerations, pool builder start with a basic pool without any fancy finishes and that is their starting point.
    Using the linear foot method with "standard" equipment, you can intelligently distinguish the high price from the low price.
    Then add the upgrades after you get the basics figured out.
    The otional upgrade on equipment is more controlled by the retail market, and in my experience, when these get added, the pricing for them is fairly equal from PB to PB.
    Divin Dave,
    Jun 2016
    Vancouver/WA
    3
    thank you, any other initial thoughts?
    size of pool?
    ballpark cost for a pool like this in the Portland, OR area?
    Nov 2015
    Carrollton tx
    451
    While you are building YOUR pool, keep in mind you might include common features that a later buyer might expect in a pool.
    I know you likely expect to live there forever but ...
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
