Thread: Previous homeowner removed concrete pool deck and left gap around skimmer
    Jan 2016
    Northern California
    41
    Unhappy Previous homeowner removed concrete pool deck and left gap around skimmer
    I recently moved into my home and it has an IG plaster pool. It appears that the previous homeowner removed the pool deck (it seems to have been stamped concrete) and replaced it with pavers. The pavers look nice (but are HOT under the sun) but they do not surround the entire pool. Previous owner was a firefighter/contractor who did all his own work DIY. One of the areas without pavers is around the skimmer. The issue I have is that the removed pool deck just left dirt around the skimmer and also a gap between the coping and the dirt. This allows water to flow out when anyone is swimming or splashing around in the pool.
    Any recommendations about how I can close this area off to keep the water in the pool?
    Side note: I may also see an exposed copper wire (assuming ground wire) coming out of the concrete that holds the skimmer in. That's not good, right? :-<
    IG ~18,000 gallon plaster freeform pool (~30 years old). Hayward single speed pump, pentair booster, DE filter, Kreepy Krawly Legend.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Previous homeowner removed concrete pool deck and left gap around skimmer
    How wide is that gap? My answer for now will be polyurethane caulk. But, I am not sure that is the best answer.
    The bare copper wire is most likely a bonding wire and it is good. More here, Pool School - Bonding vs Grounding
    Jan 2016
    Northern California
    41
    Quote Originally Posted by pooldv View Post
    The gap is 0.5-1" tall and ~10" wide. Too big for caulk.
    DFW, TX
    24,516
    Quote Originally Posted by changeyez View Post
    Agreed.
    Apr 2016
    Kankakee Il
    39
    Only thing that comes to mind would be putting a block of wood inside the skimmer as a form and pour concrete to fill the void. You could pour a square around the skimmer and finish any pavers pretty easily. Just gotta make sure your wood is secure and sealed to prevent a concrete blowout into the pool. When it's dry, pull out the block of wood. You could probably find a concrete guy to do it on the side pretty cheap as its not a big job, 4-6 hours?
