Thread: Pentair IntelliChem Salt Level Wrong
    Aug 2015
    Central, NJ
    142
    Hi all,
    I had a IntelliChem recently installed, along with a EasyTouch and IntelliChlor. The IntelliChem's salt level reading is consistently around 350 to 400 lower than my manual measurement (using Taylor K-1766). For example, the IntelliChem is currently displaying a level of 3000 but I'm measuring it at 3400. Previously, the IntelliChem was measuring 2850 while I was measuring 3200.
    Is this a typical issue? Or is this a problem? If it's a problem, does anyone know in which component the issue can exist with? The installed is a Pentair service center; however, they seem to be very inexperienced when it comes to the IntelliChem system.
    The pH and ORP sensors of the IntelliChem's flow cell were faulty when I first had it installed. After the sensors were replaced by the installer, they seem to be pretty accurate now...so now the only problem I'm having is the salt reading.
    Thanks in advance for any info.
    In-ground 47'x25' free-form gunite pool w/ spa w/ waterfall. 35,380 gallons. 3' to 8' deep. 96 sq ft 6" deep sun shelf. SunStone Select Quartz Finish (Graphite). 2 Hayward skimmers. Jandy DEV60 DE Filter + Pro Series Plus 2HP Pump. Polaris PB4-60 Pressure Cleaner Booster Pump. Raypack P-R406A Heater. EasyTouch 8. IntelliChem w/ Acid Tank. IntelliChlor IC60. Techo-Bloc bullnose coping + Blu 60 mm paver patio. Merlin SmartMesh cover. TF-100.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pentair IntelliChem Salt Level Wrong
    That is normal from what I have seen, we like to say, if the SGW is happy then your good
