Results 1 to 9 of 9
Thread: Antifreeze on top
    May 2009
    Berwick Pennslyvania
    15
    Antifreeze on top
    Help needed! I blew 2 gallons on non toxic antifreeze into my pool when I opened it this weekend. It settled on top of the pool creating an oil slick. I have put in 8 bags of shock to kill the algea but it can't break the surface. The shock combined with the antifreeze has created a white oil slick on the surface which foams up in my skimmer basket. How can I get the antifreeze out of my pool without draining all the water?
    20K gal.
    Hayward S-244T sand filter
    IG vinyl
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Antifreeze on top
    That does not sound at all like a typical reaction of antifreeze suitable for pools. What other products did you add, if any, at closing or upon opening? What are the names of the products on the packages? Did you use an algaecide?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Was the antifreeze the pink stuff for RVs and pools? That's propylene glycol, and you aren't going to see that as an oily film on the surface.
    May 2009
    15
    I just applied non chlorine shock and clarifier about 6 oz. I'm sure the antifreeze was the proper type.
    20K gal.
    IG vinyl
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    what kind was it...ie brand or chemical name? We can't help if we don't know what it is..."proper type" does not help us help you
    Regardless of where the "oil slick" came from, the solution is the same. Time and chlorine will clean it up. I would bump your FC level up a little above normal and give it a couple of days and it should clear up. A scum bug in the skimmer is also a good idea.
    May 2009
    15
    In the swim clarifier and shock. Antifreeze not sure of the brand but I know it was the correct type, I've closed the pool many times before with the same stuff. Thanks for helpful tip on boosting chlorine and the skimer insert. Any other suggestions? Thanks again.
    20K gal.
    IG vinyl
    Dec 2007
    Central New York
    504
    I would try and gentle push the oil slick toward the skimmer with the filter on waste. Hold a 2X4 floating in the water at an angle to guide the slick toward the skimmer.
    While you are doing that, keep a hose on in the pool to replace water you are wasting and keep the level up.
    Use it like this:
    image from "In The Swim Web Site"
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    May 2009
    15
    Hotrod sounds like a plan I will give it a try, thanks again.
    20K gal.
    IG vinyl
