Thread: Pump Motor Overheating - At wits end...
    Jun 2016
    Ft Lauderdale, FL
    1
    Unhappy Pump Motor Overheating - At wits end...
    Hello Folks,
    First time posting, hoping y'all can help me out of my woes.
    Last year I replaced my pool motor which died. I was not able to purchase the exact same motor (it was very old), but the guy at the pool place was able to suggest another, along with a new impeller.
    Since replacing the motor it is constantly running hot and will trip off every 15-45 mins, then turn back on after a few minutes. I assume the mechanism to prevent overheating is being tripped and shutting down the pump. I replaced that original pump with a new one of the exact same kind, same problem.
    Left it alone for about a year (yeah not smart) and the motor finally kicked the bucket. Since it was still under warranty I was able to get another one free of charge. It has the same issue.
    I assume there is something off with my set up, but based on everything I could deduce myself, I cant figure out what it could be. Everything is wired correctly, checked all voltages (~135V to the motor - within specs), no spikes, no drops, nothing out of the ordinary.
    Below is my setup.
    15x30 rectangular, marcite, 14K gallons
    1 skimmer and 1 drain
    2 inlets
    Hayward Star Clear Plus C1200 filter (runs about 15psi clean, generally clean it at 20+)
    New motor: Century HSQ 125 1.25HP
    Impeller: C105-137PEB replacement
    Pump: Dura Max E Glas ? (no sticker anymore so not 100% sure, pic below.)
    I have about 35' of head on average...
    I run the motor about 8-10 hrs a day.
    Any help on why my motor is so stressed out would be appreciated!!!
    Pool Details:14,175K Gal Marcite? 15x30 Rectangle
    Filter: Hayward Star Clear Plus C1200
    Pump: 1.25HP Century HSQ125 motor
    Cleaner: Dolphin Atlantis Robotic Pool Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump Motor Overheating - At wits end...
    The guy at the pool store mismatched the motor with the impeller. That impeller is for a 1 HP FULL RATED motor (1.65 THP). They gave you a 1 HP up rated motor (1.25 THP). So your motor is being over driven which is why it shuts down. It is in thermal overload.
    What was your old impeller number?
    Mark
