Thread: adding MA... how much at a time?
    I am in hard core lower TA via MA and aeration mode. I generally add 4 cups at a time.. but sometimes 8 cups.. Is that too much at one time?
    2003 Coleman MAAX Collection Model 706 - 400gal
    Feb 2008
    Flower Mound, TX
    Re: adding MA... how much at a time?
    Always add only enough to bring your pH down to no lower than 7.0. Anywhere between 7.0 to 7.2 pH is where you want to be. If it takes 8 cups to get it there each time, then that is what you should add. I'd just use the Pool Calculator to determine what you need to get you there.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
