Thread: Heaping Scoop
    Mar 2016
    York,Pa
    18
    Heaping Scoop
    Just got my TF-100 kit. Was reading the Chlorine Drop Test using "one heaping scoop". I looked in the DPD powder compartment and could not find a scoop. Looking in the rest of the kit, I found a 2 inch long blue plastic scoop with a measurement of 0.05 grams, in the graduated cylinder with the Calcium Hardness Test R-0011L. Is this the R-0870 powder scoop?
    Endless Pool Owner, since April 2015, 6 ft by 14 ft , 51 inches deep, 2677 gallons
    AG, indoor; 2 by 4 skylight, always covered with solar pool blanket when not in use, temp at an indicated 85, Taylor K
    Delta EA-4H UV Sanitizer, inline with circulating pump
    Pleatco PWW50L cartridge filter
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,866
    Re: Heaping Scoop
    Yep
    Great choice on test kit.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Heaping Scoop
    Quote Originally Posted by AimeeH View Post
    Yep
    +1 to that!
    30,402
    Re: Heaping Scoop
    The exact size of your "scoop" of powder is not at all critical. All you need is a scoop of powder that will result in turning the solution pink.
