Thread: Leaving an AGP covered all summer
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    A friend in NE PA has an above ground pool that she says she does not have time to open or maintain this year due to work travel and other commitments. What steps should she take to leave the cover on all year long until next summer? It has not been opened yet, no pump or skimmer hooked up....and we have had some brutally hot days up here in PA already.
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    JoyfulNoise's Avatar
    May 2015
    13,247
    I don't think there is much you can do. Without any kind of circulation, adding chemicals to the pool will be a waste or, worse, damaging to the liner.
    I would suggest just leaving it covered and making sure the water level remains in an adequate spot. Then, next year, if she does decide to open it, the earlier the better to clean up what will most definitely be a very green swamp.
    [EDIT]
    She'll still need to make sure rain water is kept off the cover to avoid collapse. So even if the pool isn't used, there's still going to be maintenance work involved.
    [END-EDIT]
    Matt
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Leaving an AGP covered all summer
    Once that water temp breaks 60-----it's game on for algae if there is zero chemicals and zero circulation. Leave it covered to keep any extra crud out and deal with it next year.
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Will algae still grow without direct sunlight getting in there? It has the basic dark/black cover on it.
    May 2015
    13,247
    The short answer is - yes, algae can reproduce in limited light conditions (no black cover is perfect).
    Matt
