Results 1 to 7 of 7
Thread: I know this may be a dumb question but...
    May 2008
    Southern Connecticut
    56
    I just looked at the weather for today and the temps overnight are supposed to be freezing (low 30s) with frost advisory. My pool has been open for about 3 weeks and its been in the 40s-50s at night. Is there anything special I have to do? Run the filter all night or not at all? The water is all balanced and salt was adding yesterday. I was planning on setting up the SWG tonight but maybe I should wait until tomorrow for that? The temps are supposed to be close to 70s tomorrow. Also I was going to put on the solar cover today (even tho there is no sun) should I wait on that?
    18' Willow round AG 52", 19" Sand filter 1 hp pump, Intex SWG 8110, Bought and install May 08
    New 12'x16' deck built March 09
    Poss thinking about solar panels next!
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: I know this may be a dumb question but...
    I would leave the pump run over night. An ounce of prevention.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The solar cover will help retain heat that is gained during the day, so it will keep the water temp up, even with cooler temps outside. I think when you have a risk of freezing that will be more than 12 hours is when you have to worry about the pipes, but I agree, leave the pump running for prevention. Using the solar now will help keep the water temp up above the surrounding air. You can wait on the SWG, I'm not sure how well it works when the water temp is that cold? Someone else will chime in on that.
    Aug 2008
    Southwest New Hampshire
    52
    I'd put the solar blanket on too now. The overnight freeze won't be a problem, and I don't think your pool would be harmed if you didn't put it on...but it will help from losing heat. And its going to be in the 80's near the end of the week!!
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    Aug 2008
    52
    Regarding the SWG... With water temps in the 50's, our system seemed to max out at about 30% output . From 60-65 degrees about 65% output. So it is producing, just not as much. If the pump is running anyway, I'd go ahead and start your SWG
    Andrew
    Jan 2009
    Cupertino, CA
    1,966
    The solar cover is a good idea anyway; it will help reduce both evaporation and radiational cooling. Re. freezing, salt lowers the freezing point of water, and water has a huge specific heat anyway (takes a lot to make it freeze), but still--running the pump (on low if it's 2-speed) is cheap insurance.
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2007
    New Jersey
    653
    Ignore these warm weather folks--I've got the same forecast. One night of this will probably not put skim ice on a bucket--let alone affect a pool, even AG. No insurance of any kind required. As far as cover, you don't say what your water temp is so any advice is meaningless without that data bit. If ambient is colder than water, then cover will retain heat keeping pool warmer. I am at 66° F water temp now, and with this forecast I will be swimming by the end of the week and I have no heater or cover. We swam this past weekend (although not much!)But I hate bathtub temp pools.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
