Hi,
I think I'm finally ready to go with a vinyl lined pool. I received this automatic quote after making selections online. Unfortunately, I'm not sure exactly what I need when it comes to brands, horsepower, efficiency, etc. If anyone has time and would like to make a few suggestions/critiques, I would appreciated it
Thanks!!
***It looks like I don't have stairs added and I purposely left out the heater because we are still deciding. I would also like to avoid any white coping and have brick laid up to the edge with concrete decking around that.
Options Description Price
Pool Type True-L
Pool Size 16' x 41' x 26' True L (designed up to 8' deep)
Pool Walls Steel $ 6,495.00
Pool Liner Liner (28 Mil - Savannah Sandstone) $ 295.00
Pool Bottom Pool Bottom (Standard Diving Pool 3'4" Deep Shallow End With 8' Deep End) $ 0.00
Corner Radius Corner Radius (2' Corner Radius) $ 0.00
Pool Coping Coping (Cantilever Coping For Bricks or Stone Around The Pool & Step) $ 0.00
Pool Wall Braces Brace (Adjustable A-Frame With Cantilever Deck Supports & Stakes) $ 395.00
Liner Over Steel Pool Step Steel Steps (12ft 14ft 16ft 18ft or 20ft Wide Step With 1 Bench) $ 2,495.00
Step Location Step Location (Other Location) $ 0.00
Pool Bench Pool Bench (2 Corner Bench Seats Fits 2' Radius Corners) $ 795.00
Pool Step Jet Kit Pool Step Spa Jet Kit (2 Spa Jets With Air Intake) $ 99.00
Pool Pump Pool Pumps (1.5 HP Hayward Super Pump Variable Speed) $ 490.00
Pool Filter Pool Filter (48 sq ft Hayward ProGrid DE Filter) $ 575.00
Pool Skimmer Skimmer (3 Aqua Genie Skimmers And 1 Return) $ 295.00
Salt Water Chlorination Systems Styles (Hayward Aqua Rite 40k Gallon Salt System) $ 995.00
Pool Plumbing Kit Pool Kit Plumbing Accessories (Deluxe Plumbing Kit With Timer) $ 495.00
Pool Cleaner Style (Hayward Tiger Shark) $ 749.00
Pool Light #1 Pool Light (300 WATT LIGHT 12 VOLT WITH 30' CORD AND NICHE) $ 295.00
Pool Light #2 Pool Light (300 WATT LIGHT 12 VOLT WITH 30' CORD AND NICHE) $ 295.00
Pool Handrail Pool Handrail (2 Stainless Steel Handrails) $ 195.00
Pool Ladder Pool Ladder (Stainless Steel Deep End Ladder) $ 0.00
Pool Alarm PoolEye PE22 $ 225.00
Pool Wall Padding Steel Padding (2 Rolls Padding For Walls/Floor, 4 Cans Adhesive & Tape) $ 189.00
Maintenance Kit None $ 0.00
Lift Gate Service Lift Gate Service (Customer Freight LTL Unload With Lift Gate Service) $ 35.00
Total $ 15,407.00
Thanks!!
Pool Type True-L
Total $ 15,407.00
