Thread: Covering your pool when not in use in swim season?
    Jun 2016
    Wilton, ME
    4
    We live in the woods. Things are constantly dropping from trees. The slightest breeze sends all sorts of debris everywhere. Plus, when we mow the lawn, try as we might, grass does tend to fly around.
    Do you cover your pool in summer when you're not in it to keep it cleaner? If so, with what? Ours is a 16' Intex metal frame pool. We're getting stairs for it, so we won't be taking them in/out all the time, instead gating the outside stairs.
    A solar cover doesn't look like it would keep junk out of the pool (I can imagine everything from on top dumping in when I try to take the cover off.)
    A winter cover seems like it's not made for easy removal, and that's what my husband thinks we should get.
    Part of me thinks we should just get a large tarp to put over it that we can roll up and store when we're using the pool, and some bungies to hold it down to some weights or to the frame. (Maybe I can convince my husband to DIY a roller thingy for it, or at least a cradle to catch it in on the back side of the pool).
    What do you do??
    Lake swimmers with a 16'x48" Intex Ultra Frame Pool (Came with our house)
    Hoping for a "real" pool someday!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Covering your pool when not in use in swim season?
    I have lots of trees too and I mow grass. Stuff constantly gets in, so I run my pump longer to keep stuff that floats skimmed off, and I got myself a robot cleaner to keep the bottom clean.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Plus one to all of that. Lots of trees, lots of mowing and lots of debris. I also do the lots of skimming to keep the debris from sinking. And you are correct that a solar cover will not work at all. Pretty much everything on top of the solar cover goes in the pool when you take it off.
    If you don't have one here are a couple of options
    INTEX Deluxe Wall Mount Surface Skimmer | Academy
    Adding a Hayward Thru-the-Wall Skimmer to Intex Metal Frame Pool (PICS!!
