Thread: Liner Question
    Liner Question
    So bought my house end of last summer, it included a 16x36 in ground pool. Been using the TFP method on it and it has been going well. The pool is about 10 years old and I know the liner is getting up there in age. I have noticed that in two of the corners there is a slight gap that has opened up at the coping maybe 1" long x 1/4" wide (see picture). Is this something to be concerned with? Should anything be done? The rest of the liner seems fine and I would like to prolong the replacement as long as possible.
    Ryan
    Sorry the pic is upside down, not sure why or how to fix it. Was fine before posting.
    18x36 Vinyl lined SWG in ground pool
    Pentair Pump and Sand filter Aqua-Rite SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Liner Question
    Hi Ryan,
    its just a short matter of time before that becomes a big rip. The weight of the water will continue to pull on it and it will get bigger and bigger. you should probably start looking for a new liner as soon as is practical for you.
    In the meantime, don't let the pool water level to the level of the rip. Water will go behind the tear and float the liner.
    Divin Dave,
    Apr 2009
    Central Minnesota
    74
    Re: Liner Question
    From the picture I can't tell if there is an actual tear, or if the liner is simply pulling out of the coping. My previous liner was prone to pulling out of the coping. You wait for a hot day where the sun is shining on the affected part, and carefully push it back into the coping with your fingers (do NOT use tools). There is a product (liner lock) that you can push in to give more tension so the liner does not pull out again. I actually have a solid piece of liner lock that goes 100% around the perimeter of my pool liner and coping.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Liner Question
    It looks like the bead has pulled loose from the coping. Very hot water can be a great help of the liner is stiff. I had a 2' corner section come loose and used 140 degree water to heat the liner enough to soften it and the bead so I could work it back in. A teapot is an excellent tool to direct the pouring. I also used Popsicle sticks to hold it in place while the liner cooled off.
    +1 on the bead lock. It can be worked in by hand (be prepared for sore fingertips). A small block of wood and a mallet is great for stubborn areas.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Re: Liner Question
    Thanks for the info, I will take a closer look when I get home but I believe it has pulled from the coping vs ripping. Is there anything that has to be done to the coping to re-insert the liner if that is all it is? Or is it just warm the liner and hopefully stretch it back and push it in? I will check into the bead lock as well.
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: Liner Question
    Nothing needs to be done to the coping. You can try working the line back in place using your fingers alone. If that does not work, use very hot water (130 to 140 degrees should do it - not boiling!) to soften the liner a bit so you can stretch it with upward pressure from your fingers.
    Steve
