Thread: How much stabilizer is in a tablet?
    Apr 2012
    151
    I searched but could not find it...I know it is a ratio, but I have forgotten it...
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: How much stabilizer is in a tablet?
    Tablets can vary quite a lot these days especially with all the 4-in-1 type products. But here's how to look at it -
    For every 10ppm FC added by trichlor, you'll add 6ppm CYA.
    A typical 99% pure 3" trichlor tablet is roughly 8oz of trichlor.
    So, if you stick those numbers in pool math, you can get a rough estimate of the number of tablets it takes to get 10ppm FC.
    Matt
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    What you're remembering is Effects of Adding Chemicals down at the bottom of poolmath. Be sure to input the correct volume up top. And read the pH disclaimer immediately below.
    Houston, TX
    1,104
    Is 6ppm of cya correct for a 3" trichlor? I heard it was 3ppm of cya for a 10,000gal pool, so if you had a 15,000 pool. it would be 2ppm of cya per tablet.
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by tstex View Post
    The exact amount of CYA and FC added expressed as ppm depends on pool volume The puck size is constant. How many million parts of water depends on pool size.
    The ratio of 10:6 FC:CYA is constant.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    One 3" tab with a weight of 8oz (most common) will raise CYA 3.3ppm in a 10,000 gallon pool. The extra .3 may not seem like much, but it does add up....
    Support the site
