Results 1 to 7 of 7
Thread: Salt Quantity
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Question Salt Quantity
    New liner going to be refilling pool from zero. Actual volume around 30K. Using pool match calculator I'm coming up with a need for over 750lbs of salt. Really?! :
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Salt Quantity
    make sure you test your water before you add, sometimes even on a new fill you will have salt already in the water... if no salt then yes, it is about that much... grab the blue bag from Lowes, its the cheapest I found but check around...
    38,548
    Re: Salt Quantity
    Solar salt can save you a bit of money. No need for the pool salt.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Re: Salt Quantity
    Yup. Really.
    and you seem to be targeting the low end of the operating range at 3000ppm for 30K gallons.
    The salt bags weight 40 lbs, so it comes to roughly 19 bags.
    Most of us use Diamond Crystals solar salt, but any brand is fine as long as its 95% or more pure and doesnt have any additives, such as Iodine. It will say how pure it is on the bag and if it contains additives.
    As Jblizzle says, you can save a bit of money. Solar is a couple or 3 dollars a bag cheaper. (4.38 at lowes vs about 7.00 average retail). The only difference is the salt grains are larger and so it takes solar salt a little longer to dissolve than the pool salt.
    The time difference is not large, only about 1/2 hour, depending on how well your pool circulates and how much you brush it around.
    Quote Originally Posted by ckk81 View Post
    Divin Dave,
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Salt Quantity
    Thanks guys! Thought it was probably right, but didn't want to accidently create a new Great Salt lake.
    Re: Salt Quantity
    Add about 80% then brush well and retest after 24 hours. That way you're less likely to add too much.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,265
    Salt Quantity
    Please remember to let your water circulate continuously WITH THE SWG OFF for 24-48 hours after you add the last bag of salt and to brush a lot. Vacuuming isn't a bad idea either.
    Too many people add their salt and then turn on their SWG too soon then get all kinds of crazy salinity readings and salinity alarms. Believe it or not it takes A LONG TIME for the salt water to homogenize as salt water is more dense. Most pool water circulation is terribly inefficient on a good day so homogenization takes a while.
    If you can, add the salt and let a few dozen kids from neighborhood play in the pool and throw salt crystals around. Splashing swimmers is a good way to mix the water.
    Matt
