Results 1 to 9 of 9
Thread: Can Hayward LEDs Color Change with Pentair Automation?
    Aug 2015
    Central, NJ
    141
    Hi all,
    I recently had my Jandy AquaLink power center changed out for a Pentair EasyTouch (as I converted over to a IntelliChlor and IntelliChem). My current lights are Hayward ColorLogic LEDs and the installer is now telling me (after the fact) that all I can do with the Hayward LEDs on the Pentair system is turn them on and off - no color change possible.
    Does anyone know if the Hayward lights should be able to be controlled by the Pentair automation? Or must I have Pentair lights?
    Thanks!
    In-ground 47'x25' free-form gunite pool w/ spa w/ waterfall. 35,380 gallons. 3' to 8' deep. 96 sq ft 6" deep sun shelf. SunStone Select Quartz Finish (Graphite). 2 Hayward skimmers. Jandy DEV60 DE Filter + Pro Series Plus 2HP Pump. Polaris PB4-60 Pressure Cleaner Booster Pump. Raypack P-R406A Heater. EasyTouch 8. IntelliChem w/ Acid Tank. IntelliChlor IC60. Techo-Bloc bullnose coping + Blu 60 mm paver patio. Merlin SmartMesh cover. TF-100.
    Jun 2015
    Orange County, CA
    144
    Re: Can Hayward LEDs Color Change with Pentair Automation?
    I think your installer is correct. Automation is usually proprietary between Hayward and Pentair. A possible workaround might be to turn the lights off/on quickly to get to the color or mode you want. This is how Pentair lights change color/mode without automation. Not as convenient as just picking a color on your remote/phone but a way to change colors/mode if Hayward lights work the same way as Pentair. Good luck!
    17k IG plaster pool+ spa, Stonescape mini-pebble midnight blue, marble coping, Trex and porcelain tile decking, Pentair Intelliflo VSP x 3 (filter, laminars and spa jets), Pentair IC40, Pentair MasterTemp 400, Pentair Quad DE 100, Pentair CC 150 for laminars, Intellibrite 5G LEDs, MagicStream Laminars x 3, Intellitouch i9+3 automation with Screenlogic2, IntellipH, Dolphin s300i, TFTest kit, SpeedStir
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Yes it should color change with a quick on/off of the power to the light.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2015
    Central, NJ
    141
    Thanks for the info!
    Yeah, I did figure that out (that it will color change if I turn it off and on)...just a bummer, because before hiring him the installer told me everything would work the same with the lights. He's willing to install the Pentair lights with me just paying his cost on the lights and no charge for labor, but even then they're not inexpensive.
    Guess I have to decide how much I'm willing to pay for the ability to select the colors. I heard the Pentair lights look nicer in the water...trying to convince myself
    Jun 2015
    Orange County, CA
    144
    Everyone's financial situation is different, so difficult to make blanket recommendations. But, I change the color/mode of my lights all the time. "American" (red, white, blue for 4th of July), plain white for kids swimming at night, sometimes I change the spa light to something different from the pool, etc. it would drive me up the wall to try to do the quick off/on to try to select the right color/mode. Also, if you plan to have Screenlogic2, I would say 100% change out the lights.
    Aug 2016
    Pittsburgh PA
    316
    I know this is an old thread but I thought I'd provide some resolution for anyone who searches the same topic.
    The EasyTouch will control Hayward lights but the programming is different (and not customizable). So if you turn on "green", it will turn on a different color (or a light show). Basically, it turns the lights on/off until it thinks they are Green (based on Pentair programming). But because the programming is different, the lights will land on a different color than Green.
    Unfortunately, our brand new pool was built with Hayward lights and I installed an EasyTouch system. I'm having the builder swap out the 2 lights so everything works correctly.
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    Aug 2015
    Central, NJ
    141
    Quote Originally Posted by Veccster View Post
    Thanks for the update. Last year, I ended up asking the builder to swap my Hayward lights out for the Pentair lights and he was only able to do so for my spa light. I have two other lights in my pool and he said that he couldn't fit the Pentair housing in place of the Hayward light housing. Does anyone know if that could be true? It's really strange because he's a reputable builder in my area and is certified by Pentair. I believe he really doesn't think it's possible because he didn't even charge me for the $500+ spa light that he put in as he felt bad about the situation. Still isn't a great situation for me because now I have 1 Pentair light in my spa and 2 Hayward lights in my pool, and still no light programming features (except turning them on and off).
    Aug 2016
    Pittsburgh PA
    316
    So you have EasyTouch and Hayward LED lights? Is what I said above correct....that the EasyTouch can turn them on and change colors but the programming is not matched up - so the colors are not correct???
    I had the Pentair Field Service Manager at my house this morning...he's who explained why the EasyTouch wouldn't work with my Hayward lights. He recommended that the lights be swapped out for Pentair lights so they can be correctly controlled. I asked if it's a simple swap and he said it was....just remove the screws and fish the wire up conduit.
    I haven't done it yet but I trust the Pentair rep who said I could without a problem.
    I'm hoping there won't be much cost to me as the builder will use the Hayward lights on the next pool he installs.
    Aug 2015
    Central, NJ
    141
    Yes, I have EasyTouch and Hayward LEDs. The EasyTouch can turn the lights on. Each time the lights are turned off and back on, the light setting randomly changes to a different setting. I haven't been able to get the EasyTouch to try to switch the colors, as I had a Pentair tech come by last year and unsuccessfully try to do so. I'm going to follow up with the builder that I used last year to try to get him to give switching them out for the Pentair lights another shot.
