Results 1 to 19 of 19
Thread: Fun and confusing at pool store
    May 2016
    MD
    195
    I know, don't trust their numbers. I went and asked about parts for something and had them just check the numbers for fun.
    Still throws me though.
    I can't figure out how my CYA is going up, being i have put 5 lbs of dry PH down in over a couple weeks before figuring out what Murnuric (sp) acid is and what it does, and bleach and the acid is the only other thing I put in it...
    but I am even getting a bit higher number of around 100, when i was under 90 before, and theirs is at 130 when it was 85 at the store after i took all the pucks and quit using shock out.
    they say my TA is 97... my test is 200 still.
    PH 7.9 on their test, when i get 7.6 or so... a little dripping water really makes it go up fast as it was 7.3 on sunday.
    and their FC is 8.2 when I am at 11...
    so yeah... way off of what I get, but they didn't even try to sell me anything...
    Figured I would share
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Fun and confusing at pool store
    What is your water temperature, the CYA turbidity test will read false low with cold (below swim temperature) water
    Jun 2014
    15,008
    Well, we're never surprised that pool store tests seem different. If at any time you feel uncertain about your numbers though, check back with us and we'll clarify the testing process for any of them. Once you get confident and some practice under your belt, you can always rely on your testing number over the pool store. Have a nice weekend.
    Hopefully you have a speed stir as well. That makes a difference.
    May 2016
    MD
    195
    temp is 80
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    439
    CC= 11? What do you have a rotting animal carcass in the deep end or something?
    I've been in the pool store exactly once in the last 13 months and that was only to get replacement gaskets for my tank-to-spider-valve connection and plugs for the pump skimmer basket. At some point, it might be fun to see what they say about my water.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    May 2016
    MD
    195
    High CYA... : My reading is FC 11 CC 11.5 ish... one drop gets rid of it.
    theirs was 8.9
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Puppiesonacid View Post
    theirs was 8.9
    So your FC is 11, your CC is 0.5 and your TC = 11.5
    Isolated Spa - 345 Gallons
    Husky25's Avatar
    Jun 2015
    439
    theirs was 8.9
    I got it now. Your OP says CC=11. May want to edit that.
    Chris
    May 2016
    MD
    195
    yes
    All the letters throw my add/ dyslexia
    where you get a speed stirrer?
    Jun 2014
    15,008
    From the TF-100 web site (link below in my sig).
    May 2016
    MD
    195
    Got it, thanks ordered one...
    triptyx's Avatar
    Apr 2016
    1,438
    You'll love it. I couldn't imagine testing without mine - having to carefully swirl constantly. *shudder*
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2016
    MD
    195
    I just thought of something funny. The lady said she was selling more ALklinity up then ever before after their system did a update. Well I get why if it is 100 below what i came up with on my own.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You should never chase a TA number, you should adjust TA to where YOUR pH is stable, every pool is different
    30,403
    All newbies say mostly IDENTICAL words...."just for fun, just for giggles, giggles and grins, etc" I don't understand when the fun begins? It is hard enough to learn this new jargon, learn how to do these new tests, etc.
    Why in the world it seems helpful or "fun" to bring in a completely bogus set of test results and start down the path of confusion is mystifying to me.
    May 2016
    MD
    195
    Well, every place may be different, and they could give honest numbers somewhere... They have a computer system that checks the water. was hoping it be closer to my numbers... but now I know for sure.
    30,403
    Well, you are right and I must apologize for being a bit harsh. You would think Pool Stores to be a great place to "meet the experts" but, in fact, it is most always the opposite.
    It's literally a misconception that Pool Stores are a source of accurate info but they print out that computer sheet that says, " You really need to buy this...." and that's where you end up.....tossing chemistry in your pool that you don't need.
    I am a small business person and have always tried to defend and support small business but I have been unable to support the Pool Store idea for almost ten years now......they simply do not earn our respect.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The problem with so many of these "computer systems" is that they report their results to 2 points past the decimal place, so many people confuse this level of precision with accuracy. For accuracy some of these computerized systems may be better than others, however to achieve this potential level of accuracy on any of these units they must be used correctly and maintained, this means being calibrated with reference standards, cleaned, and operated properly. If we look at the typical pool store, and pool store employee things like careful sample handling is obviously lacking, to which way may infer that the rest of the chain of proper operation and training may also be lax.
    In my personal opinion the best computerized unit out there at this time is probably the LaMotte WaterLink Spin Lab, however even here if you watch the official training videos you can see that proper operation is a must to get reliable results, and 2 key factors here are filling the sample disks using a CLEAN syringe so as to avoid micro air bubbles, the disk must also be placed on a CLEAN surface will filling this is to prevent surface contamination touching the bottom of the sample disk. Now ask yourself this, have you ever seen a testing station at a pool store that looks like it even comes close to the necessary conditions? In particular have you seen the pool store employees handle the filling of a spin disk so as to even check for micro bubbles?
    May 2016
    MD
    195
    I own a business too. I hate when small business are the ones that screws people. I compete with big box stores and they screw my industry up horribly... some small guys do too... maybe i need to own a pool store and do it right too Though I guess if everyone got smart, the pool places would go away, other than for closings and openings Or call it "Just Bleach"
    Quote Originally Posted by Isaac-1 View Post
    Sounds like you used one before I know it took her 4 times to get the thing right in the first place. as for clean syringe. eh... not really sure to be honest... i didn't watch that close and they are behind a desk
