Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: New Radiant Metric 16*32 oval installation
    May 2015
    Charlton, MA
    30
    We pulled the trigger and bought a Radiant Metric 16*32 oval.
    I plan on documenting the entire project here as there isn't a lot of real detail online regarding these pools.
    There are a few posts of these installs on this site that are very helpful, but most are of the round metric pools and some details that I was searching for were not available.
    I plan on sinking the pool down about 2 feet and build a stone patio around it.
    This is the yard last year
    Same view after hole and trenches.
    16*32 Metric Radiant Pool
    Pentair Intelliflow VF pump, Pentair IC-40 Chlorine Generator
    Pentair 320 sq/ft cartridge filter,Pentair Intellibrite 5G LED lights
    900 SQ/FT stone patio under construction.
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,670
    Re: New Radiant Metric 16*32 oval installation
    Fun project! Love that gazebo. What a great space to work with.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    May 2013
    Albany, NY
    59
    Looking like a great start, and a beautiful property! Post lots of pics and shoot me a PM if you have any questions or need clarification on anything!
    Eric Adams, Technical Specialist, Radiant Pools
    May 2015
    Charlton, MA
    30
    Thanks! That yard was a few years ago when the lawn was looking real good.
    I do have a question about the stairs to wall mounting.
    I leveled the stairs based on the top rim around the steps. The problem I am running into is that the sides where I bolted the wall mounts to is leaning forward about an inch into the pool area. This is causing my level walls not to align.
    I see 3 options, please give me your thoughts on the best practice.
    1. Remove some sand from the back legs of the steps so they unit will be tilted back about an inch, but the mounts will align to the level walls.
    2. Adjust the wall mounts on the stairs so they are level with the wall. If I do this the wall mounts will set back about an inch from the face of the steps at the top, while still flush at the bottom.
    3. A little of each. Drop the back of the steps 1/2" and tilt the wall mounts back 1/2".
    If you need pics I can provide.
    Thanks
    May 2015
    Charlton, MA
    30
    Trying to upload a couple of new pics, but I have exceeded my quota. Not sure what that is about.
    Jun 2016
    Upstate NY
    47
    Since your going 2 feet down do u plan on putting concrete collar around base? Looking to do same maybe 2 feet down with oval or round radiant
    May 2015
    Charlton, MA
    30
    Well, I went with option 1. The stairs are slightly tilted back. I found a couple pictures and a video online that showed the seam connector almost flush with the front of the stair flange. The diagram in the manual also shows this.
    All walls are up with the exception of the one corner where we will truck the sand in.
    Sure wish I could add some pics.
    May 2015
    Charlton, MA
    30
    jpelizza,
    Yes, I will be putting a full collar around the pool. I plan to have the pool about 52" deep except within 12" from the wall, there will be a quick 3" drop. That means I cannot use the wall ties, so a collar is a must.
    May 2015
    Charlton, MA
    30
    Can a moderator PM me and explain why I cannot post any pictures? I am above my quota?
    Thank You
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    16,395
    Quote Originally Posted by Egghead2004 View Post
    Thank You
    You only get room for about three pictures (256 kb), unless you become a paying supporter. But you can open an account on another site and link directly. Posting Photo's Tutorial
    May 2015
    Charlton, MA
    30
    Thanks Richard320, I will become a paying member. I have learned so much on this forum in the last year, I owe it.
    May 2013
    Albany, NY
    59
    PM sent, looking forward to pics!
    May 2015
    Charlton, MA
    30
    Here are a couple of pics. This is just prior to mounting the stairs.
    Now I am waiting for the rain to stop so I can bring in the 4 yards of masonry sand.
    May 2015
    Charlton, MA
    30
    Pool walls and stairs are all complete. Ready to install steel plates and drift pins. Concrete collar coming Thursday...I hope.
    May 2015
    Charlton, MA
    30
    The collar has been poured, now into the lights, returns, and liner
    Casey's Avatar
    SW PA
    9,964
    This is a nice pool. Can't wait to see more progress!
    May 2015
    Charlton, MA
    30
    Sand is spread, packed, and leveled.
    May 2015
    Charlton, MA
    30
    May 2015
    Charlton, MA
    30
    Lots of notes taken. Will provide a detailed post when the pool is open.Image1467692286.434007.jpg
  20. Back To Top    #20
    Jun 2015
    East Meadow/NY
    82
    Great build. I am having my radiant 14x22 freeform installed Friday.
    14x22 radiant freeform, 6800 gallons, Semi AG, DE Hayward, Hayward SP1580X15 Power-Flo LX Series 1-1/2-HP, installing 7/14/2016, TF100
