Thread: Please Help With Stabilizer After Algea Bloom
    May 2015
    Chardon, ohio
    22
    Thanks for reading this. I opened my pool last week to an algea bloom which is about 95% cleared at this time with continual shocking. CYA is 0 and I am blowing through 3 gals of bleach a day not to mention pucks as well to try to bring up CYA. Not working. 10-12 at night when I add bleach. 9 in the morning, 0 when I get home from work.
    Please help with advise on how to stabilize my pool since I've never done it before. I live in Cleveland and CYA is always 0 at opening. Always used pucks in the past but don't want to any more because it takes to long to bring up CYA. Don't know if its good to mix with bleach. I've heard to put 1 lb at a time in a sock and put in the skimmer. Soak 1-2 lbs at a time in warm water and break it down before pouring it in the skimmer. Leave the filter on for 48 hours after adding. Don't worry about it. Add liquid stabilizer to speed up the process. Watch the filters because they will clog. I'm lost....
    Questions
    Should I stop using pucks to bring up CYA since its taking too long?
    Can I add stabilizer while the chlorine level is high?
    What is the best type to use and how exactly to do this process?
    I need to get the pool stabilized so I don't blow through so much chlorine. Thanks for any advice you can give or a page to go to that has instructions. Thanks
    22000 Gallon in ground vinyl pool built in 2000, sanitized with chlorine
    Hayward C900 Cartridge Filter, Hayward Super Pump, 1HP, Single Speed
    Taylor test kit
    I have well water and do not use it in my pool. Have water trucked in when I need it.
    I live in the Cleveland, Ohio area
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Please Help With Stabilizer After Algea Bloom
    HI there.....yep you need some stabilizer in there. Regular granular stabilizer sold (at least here) at Walmart is fine...may say conditioner but your looking for active ingredient cyanuric acid. We usually reccomend putting it in an old sock and suspend in front of a return. I actually tie mine to pool noodles and try to agitate the socks when I'm around to help dissolve.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    30,431
    Welcome to the forum.
    See if you can pick up the directions for how to do the SLAM process up in Pool School. 20/20 hindsight but it's where you should've started. Read that article and then ask us questions......we'll get you all cleared up and save some FC.
