Thread: Pool socks effect on chlorine
    Aug 2014
    NJ
    435
    When a pool sock is used in the skimmer the skimmer basket retains a lot of dirt and other stuff which would otherwise flow through to the filter. Does that cause the pool to use more chlorine while it attacks the stuff retained in the skimmer basket?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Pool socks effect on chlorine
    Nope.
    That same debris would just be sitting in the filter otherwise. Same water. The chlorine would be working on it out of sight in the filter if it weren't trapped in the sock.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The socks should actually reduce your chlorine demand if you think about it. Rather than being trapped in the filter for a longer period of time (between backwash or cartridge cleaning), if you remove and clean the socks regularly, you're removing that material from the pool circulation system sooner.
    Isolated Spa - 345 Gallons
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    I would say no, the same chlorinated water would also be flowing through the filter and meeting the stuff in there as well.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Aug 2014
    NJ
    435
    Thanks everyone. Good to know.
