Thread: My pool is un level about 2inches!
    Jun 2016
    Dunkirk NY
    1
    Hi , I just bought a pool yesterday and it's all filed up today ! I thought the ground was pretty level until it was all filled and I notice this morning the shallow end is leaning towards the end that's holding more water. The pool is 18 by 48 inches and is a Coleman power steel pool. My question is this do I have to un drain this pool and find a level area and re fill it again?!? One end measures 37inches and the other end measures 40inches. This pool cost me 400$ and I don't want it ruined but I also don't want to tear it apart if I don't have too !! Let me know my options thanks
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    Re: My pool is un level about 2inches!
    Your only real solution to your problem is to drain the pool and take it down then relevel the site by digging the high side down to match the low side. A long 2x4 on edge with a 4 foot level should be able to get you level enough for the pool.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP! Congrats on the new pool!
    CJ has you covered here. A little shoveling will get you there. You are looking for level within one inch, or less.
    jmcdtucson's Avatar
    Jun 2014
    317
    And since no one has mentioned, an out-of-level pool can not only ruin the pool but get someone injured in the event of catastrophic failure. So it's important to get it right.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
