Thread: Air coming out of return
    Feb 2015
    North Alabama
    58
    This morning I cleaned the filter basket by my pump. When I put it back in, I noticed it would only stay about half full of water. Lots of air was coming out of the returns, and the pressure was very low coming out of one of the returns. When I turn OFF the pump, water leaks out of the filter basket area. Also, the pump sounds noisier.
    What do I do?
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Air coming out of return
    Open pump basket (what I believe you are calling the "filter" basket). Make sure mating surface is nice and clean of debris. Check that the gasket is intact and properly seated in the channel. If it looks good, apply a nice layer of Magic Lube to the gasket.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jul 2015
    Central Valley CA
    1,107
    Sounds like you have some debris between the lid gasket and the base or a bad gasket. I would take the lid off and inspect the gasket make sure it is clean and not broken on nicked. You may want to get some silicone lube for a tighter seal too. Hopefully the pump being noisier is just air going through get the lid fixed and it should quiet down.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2015
    North Alabama
    58
    Thank you! This did the trick.
