Thread: Sealing screws for light
    May 2016
    MD
    195
    I can't seem to find a 2 inch screw with a little gasket in the middle to pull the ring tight that seals the light fixture.
    I am replacing most of the light. IE seal and bulbs... I have one screw with the nut on it, but no tiny rubber gasket in the middle, and the other is missing the nut.
    I am not sure it needs the gasket. But not sure since neither has one.
    Just wondering if anyone has a site to find them on? I sure can't...
    Pentair 78458100 Amerlite 120V, 500W, 50' Cord with Stainless Steel Face Ring Pool Light
    Looks similar to this for the fixture
    Thanks
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    30,419
    Re: Sealing screws for light
    That screw, I believe, is a special bi-metallic screw that is used to help reduce corrosion between to disparate types of metal. That's gonna be tough in the hardware store.....I would get pentair involved to get the one you need.
    I don't think the "gasket" feature is important....I think it's more of a "washer" to give a nice, snug fit.
    May 2016
    MD
    195
    If any washer will do, i can get those and a new nut... i have the screws... though one is rusted a little... guess i will make a call.
    Thanks
