Thread: Swamp pool keep adding chlorine
    Jun 2016
    Rehoboth
    1
    Opened my pool the other day and it was as green as a swamp. I added 12 gallons to try to shock the pool but when I test it it comes up as zero chlorine levels still. I am running the filter all the time. Should I keep adding more liquid chlorine until chlorine level comes up? I would think it would have by now. I have a 27ft round above ground pool.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,549
    Re: Swamp pool keep adding chlorine
    Hi! We can fix your pool right up! We do need some help to do it. What are you using to test with? Can you please put your State on your location and fill in your signature so your pool info. show on each post. (settings-upper right, edit signature-middle left) Pool size (gals) and type, filter size and kind, any special features? ect. THANKS!
    Kim
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,261
    I might sound like the shopping channel, but by following Trouble Free Pool Care and getting free advice from volunteer experts here, you will learn to run your pool for less money, and that green may never happen again.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
