Thread: Help diagnosing if my filter motor is gonzo
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    117
    After realizing my timer was not the issue.. I have come to realize my motor isn't working. It is from 2003 - a USQ1102 1 hp filter.
    Looking at it, it looks good. But it is not turning on. We had a brief power outage this am, and this afternoon I noticed the filter was not running.
    We also have a non functioning SWG which is still connected to the whole set up.
    Main issue today is the motor.. can anyone help me to figure out if I need a whole new filter motor, or just a part?
    I can not seem to find any diagnostic steps online.
    I am attaching pictures as well. Thank you all so so so much
    In ground Liner, MBP-125A Heat Pump by Aqua Heat , built 2003, 18x37 Grecian style, System 3 sta-rite filter. @22,000 gal, tftestkits TF-100 & 1766, USQ1102pump installed 6/2016, new liner installed 07/2017. Circupool SJ40 SWG ( to be installed 06/2018)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Help diagnosing if my filter motor is gonzo
    Did you check the breaker panel for the house. Many times the pump is on it's own circuit and perhaps the power outages caused the breakers to trip on the pump. Do you hear any humming or feel vibration on the pump at all when it's supposed to be on?
    Isolated Spa - 345 Gallons
    PureLuck's Avatar
    May 2016
    Hopkinton, MA
    117
    Nope. No sound. Already checked breakers, and reset main. Originally thought it was the timer that blew. I have the option to get a minimally used Hayward Power flow LX 1.5 hp from a neighbor. Would that work in place of my current AO USQ?(that's a1hp)
    mas985's Avatar
    Pleasanton, CA
    11,737
    The Power-Flo LX is not a self priming pump so will not work if the pump is above water level.
    Mark
